Update on Lighthouse Sculpture | 15 comments (15 topical, editorial)
Re: Update on Lighthouse Sculpture (3.00 / 0) (#10)
by Dave B on Mon Dec 26th, 2005 at 11:17:58 PM MST
Hi, Rich & Aaron,
  A very easy way to build an LED bargraph or dot meter is with the LM3914 IC. I am using this to trigger my solid state relays (for a vaiable load controller using hot water heating elements) at any selected voltage indicated by a "lit" LED. I also have a potentiometer on the DC input to set the meter level to start at basically any voltage which then is linear throughout the range. I have 2 IC's which sequence 15 LEDS, first 5 green, 5 yellow, 5 red. Just thought it might be something for you to check out. Here's a link  http://www.uoguelph.ca/~antoon/gadgets/lm3914.htm  If that doesn't work just google search LM3914. Good  luck with your projects, it looks great.  Dave B.
Re: Update on Lighthouse Sculpture (3.00 / 0) (#12)
by Aaron on Tue Dec 27th, 2005 at 05:04:00 PM MST
thanks dave b. i will look into this option. so much to learn.....
aaron
Update on Lighthouse Sculpture | 15 comments (15 topical, 0 editorial)
