Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Rants & Opinion
Diaries
Our Products
Update on Lighthouse Sculpture
15
comments (15 topical, editorial)
Re: Update on Lighthouse Sculpture
3.00 / 0
#9
by Aaron on Mon Dec 26th, 2005 at 06:04:10 PM MST
User Info
wow is right, looks like i better go back to school for electronics before i finish this one. thanks rich, i'll also be filing this for rereading.
thanks for the direction,
aaron
3.00 / 0
#10
by Dave B on Mon Dec 26th, 2005 at 11:17:58 PM MST
User Info
http://www.madbbs.com/users/bruggelog
Hi, Rich & Aaron,
A very easy way to build an LED bargraph or dot meter is with the LM3914 IC. I am using this to trigger my solid state relays (for a vaiable load controller using hot water heating elements) at any selected voltage indicated by a "lit" LED. I also have a potentiometer on the DC input to set the meter level to start at basically any voltage which then is linear throughout the range. I have 2 IC's which sequence 15 LEDS, first 5 green, 5 yellow, 5 red. Just thought it might be something for you to check out. Here's a link
http://www.uoguelph.ca/~antoon/gadgets/lm3914.htm
If that doesn't work just google search LM3914. Good luck with your projects, it looks great. Dave B.
Parent
3.00 / 0
#12
by Aaron on Tue Dec 27th, 2005 at 05:04:00 PM MST
User Info
thanks dave b. i will look into this option. so much to learn.....
aaron
Parent
15
comments (15 topical, 0 editorial)
create account
How to use the board
FAQs
search the board
Google search the board
Old Otherpower Board
