Tesla Turbine & Solar | 9 comments (9 topical, editorial)
Re: Tesla Turbine & Solar (3.00 / 0) (#2)
by Ungrounded Lightning Rod on Thu Feb 17th, 2005 at 11:06:09 PM MST
I never really thought about a tesla turbine would have high horsepower and low speed, and when incorporated with a solar array, thats just toooo good to pass up. has anyone tried this?
Power-to-weight ratio yes.  But low speed (or high torque)?  Last I heard a Tesla turbine has extremely high speed and pretty low torque.  (Even one of those web pages is talking 2,000 to 10,000 RPM, which seems a bit low for a Tesla to me.)
(Did I miss something in one of the articles?  Other than the low-speed experiment with water to try to track the flow streamlines?)
It's hard to get torque when you're depending entirely on friction of a fluid running along a flat surface to connect the working fluid to the turbine.  Teslas run at extreme speed and need little torque to achieve high horsepower.
The reason they're using Teslas is that they're using the solar collector as a boiler.  Decently efficient tesla turbines are a snap to construct compared to a vane-style turbine or a piston-style steam engine.  They're also small and light.
A high-speed low-torque prime mover makes for a small, cheap, light high-frequency generator, too.
Re: Tesla Turbine & Solar (3.00 / 0) (#3)
by iFred (ifred2006@yahoo.com) on Fri Feb 18th, 2005 at 04:45:05 AM MST
They appear to have modified the internal tesla turbine with blades and spacing to produce a decent rpm. Most motors and generators are running in the 2000 rpm range, so want i find interesting is if this could also be used to run a 3 phase induction motor at 10% it's rating, or even put a dual rotor or conversion on the turbine and see what happens, not to mention a car altinator..ummm.. they have suggested that with the modificatons in the 2000-5000 rpm range your getting around 4-8 HP and with a 6inch turbine, which is just about right on for a nice dual rotor generator or so.. I think I want to play with this and see what happens come summer time..
Re: Tesla Turbine & Solar (3.00 / 0) (#5)
by Kwazai (mswayze@truswood.com include otherpower in subject) on Fri Feb 18th, 2005 at 12:08:53 PM MST
they are definitely making it happen,some of the other pages were related to flash stem to drive a tesla turbine and blade spacings for steam (different for air). I had read some stuff previously that said a minimum of 60 psi, but one of the articles looked like the guy was getting sluggish performance at 30-40psi steam. a lot of stuff in there related to collector dishes and troughs too.
cool sites, thanks.
Mike
Re: Tesla Turbine & Solar (3.00 / 0) (#6)
by iFred (ifred2006@yahoo.com) on Fri Feb 18th, 2005 at 05:19:44 PM MST
I have an old 6 ft sat dish, I wonder if it's big enough to play with.. most of what they start with is like 10-12ft. I was thinking broken mirror pieces cemented and orientated correctly might do it, but I could be totally wrong. any ideas on mounting mirrors on a dish? The troughs look more appealing from a simple point of construction and materials needed. they suggested temps 300-400f for something like 15ft long.
Tesla Turbine & Solar | 9 comments (9 topical, 0 editorial)
