What is the width and thickness at the tip? (Every plan I come up with has 1mm thick for the last 2 stations!)
I have no idea whether it will do why you need done, and it won't arrive in time for us to check it out and five you a review.
But at $175 the price is right and it is reviewed elsewhere.[ Parent ]
Just for fun I downloaded the trial version of Rhino 3D a couple of days ago. It's a fully functional demo so you can actually try it out. It's limited to a certain number of saves.
There's also a demo for Rhino Cam which as the name implies will produce G code and toolpaths directly from whatever you drew in Rhino 3D.
I don't have my machine done so I can't speak for how well this will work but it seems quite easy to use and there's a neat cut simulator in the CAM section.
Of course it will be a lot more than $170 ;(
Ted.[ Parent ]
