1 foot CNC wood blade for a 3 blade 2 foot prop | 20 comments (20 topical, editorial)
Re: 1 foot CNC wood blade for a 3 blade 2 foot pro (3.00 / 0) (#9)
by gibsonfvse on Tue Feb 22nd, 2005 at 01:04:16 PM MST
Well-done on this!  If I may ask, what CNC mill are you using?  I would expect the trailing edge to be paper-thin, especially if your airfoil profile is like this, and it's not a bad thing, necessarily (sharp trailing edges are good).  Maybe a good thing to do would be to strengthen the trailing edge with some layers of fiberglass.  Just a thought... keep up the good work!
- Chris
Re: 1 foot CNC wood blade for a 3 blade 2 foot pro (3.00 / 0) (#10)
by richhagen (richhagen (a t) Juno.com) on Tue Feb 22nd, 2005 at 01:29:23 PM MST
It's a Taig mill.  I think I need to strengthen the trailing edge a bit, but want to keep the design as simple as possible.  I figure that the required strength of the blade material increases with the rotor diameter, and that if Dan and Hugh can use wood on their beasts, then I ought to be able to use wood for a smaller one.  If I get a blade I like, I may make a bunch of them, as I have a bunch of small motors collecting dust.  Rich Hagen
The Mill (3.00 / 0) (#12)
by richhagen (richhagen (a t) Juno.com) on Tue Feb 22nd, 2005 at 02:00:56 PM MST
similar to this one:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=58254&item=3875320084&rd=1
-Rich
Re: 1 foot CNC wood blade for a 3 blade 2 foot pro (3.00 / 0) (#13)
by newguy on Tue Feb 22nd, 2005 at 03:07:49 PM MST
does anyone use a shopbot cnc
ShopBot (3.00 / 0) (#14)
by wdyasq on Tue Feb 22nd, 2005 at 05:20:45 PM MST
I use a variant.  It uses ShopBot drivers and software.
1 foot CNC wood blade for a 3 blade 2 foot prop | 20 comments (20 topical, 0 editorial)
