Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Rants & Opinion
Diaries
Our Products
wood gas
33
comments (33 topical, 0 editorial)
Re: wood gas
3.00 / 0
#14
by mikey ny on Thu Mar 31st, 2005 at 05:50:10 PM MST
User Info
Sounds like a pretty good method using a small compressor after the filter and then into the propane tank. If understand this correctly I would connect a pipe from gasifier to the air intke side of the compressor If i have a place to thread into. The gas will then pass through the compressor and into the tank. Sounds good, even if the gas eventually contaminates the compressor I will throw it away, the small ones are real cheap. The only concern i have is heat and friction in the compressor and the possibility of ignition. I think it may be safer to let the gasifer fill a tank, 55 gal drum or some type of container with its own pressure, when the gas fills the tank, close it off. Then apply air pressure to the tank with a rubber air hose. I believe the tank should be grounded to a ground rod to help avoid a spark from any static electricity that could accumulate during the process. I think the idea with the compressor would be a lot easier if i could be sure the thing would't explode because of a spark from friction in the compressor. I think i have a long way to go before accually atempt this experiment.
Mr. Mikey... "I thought I made a mistake but I was wrong"
Parent
wood gas
33
create account
How to use the board
FAQs
search the board
Google search the board
Old Otherpower Board
