wood gas | 33 comments (33 topical, editorial)
Re: wood gas (3.00 / 0) (#22)
by nothing to lose (nothingtolose175 at yahoo.com) on Mon Apr 4th, 2005 at 02:05:29 AM MST
I dought I would use antifreeze myself.
Depending where a person is at and how bad the winters, just insulate the barrels and use a solar water heater sitting in the sun. As long as the water stays above freezing I dought there would be a problem. If you have bad winters and need alot of heat, just make lots of gas, making the gas should warm the barrels, and you'll probably be using alot then anyway right :)
wood gas | 33 comments (33 topical, 0 editorial)
