wood gas | 33 comments (33 topical, editorial)
Re: wood gas (3.00 / 0) (#6)
by healerenergy (healerenergy@yahoo.com) on Tue Mar 29th, 2005 at 08:38:21 PM MST
(User Info) ourgreatawakening.com
If you keep air out of your system you should be ok but build your system as far away from builbings as possible. We did wood gas experiments with heat in high school science class and we used the charcoal after to burn for other things. If I had the ability I'd make some gas now just for the charcoal for my forge it's great for making damascas for knives. If you use a parabolic trough you might get enough heat to produce gas. With all things be careful.
Energy comes from many Sources the trick is knowing how to tap into it.
wood gas | 33 comments (33 topical, 0 editorial)
