Zubbly,
>From what i can see, it is wound with a coil
>span of 1-4, the slots are skewed by 1 stator
>slot, i think from the looks it is 72 stator
>slot (hard to see from picture)
>and has 24 mag poles on the rotor. I also
>noticed that the stator lamination thickness is
>only 3 inch wide. The mag poles appear to be
>formed from 4 rows of mags per pole.
The above is all correct except that the pole pcs.
on the rotor are laminated steel and the mags must be buried beneath them
<From the 400 cycle stamped on the nameplate and <br>
<the 1710 rpm,(24 pole), they must have been <br>
<using a gear drive from the propellar. Do you <br>
<have any idea what diam the original prop was <br>
<and how many blades?<p>
They used a five to one gear ratio and three
blade with a nineteen foot dia.
The blade were hollow aluminum with louvers at
the root and exits at the tip to evacuate
the wind piled up at the center.
They claimed higher efficiency, however the hollow
blades broke and were not very efficient that way.
<Lastly, what will you be doing with the <br>
<alternator now?<p>
I hope to sell it to recoup some of my cost in
purchasing the inverter.
By the way, I need the service manuals for the
inverter and the schematics if anyone has any
info.
Garry
