Lenz turbine variation pics | 17 comments (17 topical)
Re: Lenz turbine variation pics (3.00 / 0) (#13)
by RobD on Mon May 23, 2005 at 06:18:04 AM MST
Looks good Hanski, I'm wondering how the material will hold up over time and weather. What size alternator are you using and what is the cut in speed? Rob
Re: Lenz turbine variation pics (3.00 / 0) (#14)
by Hanski on Mon May 23, 2005 at 01:48:36 PM MST
Rob,
Aluminium blades should be OK. Other metal is mostly stainless. I'm little bit worried about the plywood and I'm going to handle the edges somehow. The wooden profiles inside blade got oil treatment. We call it woodoil which is made for outdoor furniture. They might hold two years?
Alternator is small 7,6 inches with 12 (24) 0,8inch neos. If I get 100W I'm happy, 50W is OK. Cut in speed is 100rpm.
It looks a bit crude but this is my first project ever so please forgive me.
//Hanski
Re: Lenz turbine variation pics (3.00 / 0) (#15)
by alcul8r on Mon May 23, 2005 at 02:17:10 PM MST
Nothing to forgive there....
If you have tried anything at all you are ahead of 99.99% of the population.
alcul8r KansasWind.com
Re: Lenz turbine variation pics (3.00 / 0) (#16)
by RobD on Tue May 24, 2005 at 07:28:26 AM MST
Looks fine. you don't want to invest a lot of time making a super good looking project when you get started . All my beginning projects were major failures as I'm sure most other builders projects were. Lots of people build big projects for there first mills and unless the project is through someone who has done it before they rarely amount to much.
Re: Lenz turbine variation pics (3.00 / 0) (#17)
by ghurd on Tue May 24, 2005 at 09:17:04 AM MST
I will second that.
Even more so if it is not a proven design with plans.
