Lenz turbine variation pics | 17 comments (17 topical)
Re: Lenz turbine variation pics (3.00 / 0) (#6)
by Matrix1000 on Sat May 21, 2005 at 10:42:50 PM MST
Thats what I was thinking, perhaps 2/3 stacked on top of each other staggered 1/2 / 1/3 of a turn. Then it might self start yet still retain the same efficiency.
Re: Lenz turbine variation pics (3.00 / 0) (#7)
by pyrocasto on Sun May 22, 2005 at 12:31:24 AM MST
I've seen it done on many comercial turbines and concepts, but I was starting to wonder why hardly any DIYers did it. :)
Re: Lenz turbine variation pics (3.00 / 0) (#8)
by rotornuts on Sun May 22, 2005 at 01:38:53 AM MST
Hi guys,
I'm totally mew to the vawt club so I'm still learning and I've learned a few thing here. I think three is probably going to prove better than two. This thing only has a TSR of about .7 so it needs a total redesign. I think the blades are too big and the venturi is in the wrong spot on the upwind side. I think I need to keep the air flow to the outside of the rotor on the upwind side till it comes past 90 degrees or it creates too much drag and the negative pressure behind the unit is wreaking havoc in the two blade design. The ropatec handles things a bit differently but I think some of the same problems may exist there too although I'm starting to see the merit in the delta and the football for the three and two blade designs.
BTW Xray that's a very fine unit you built.
I'm about to post drawings of my next learning experience with links back to the former posts so plaese give me your thoughts.
Mike
