Biodiesel | 25 comments (25 topical, editorial)
Re: Biodiesel (3.00 / 0) (#16)
by RobD on Sat May 21st, 2005 at 06:35:28 PM MST
How about machining yuor own injector and preheating the oil just before it goes into the manifold?
I think it would work but the plugs might not last long. Also the hot oil would probably cause some preignition.
The cranks aren't heavy enough on the Briggs, maybe a Kohler could hold up to the forces of going to diesel on a gas engine.
Re: Biodiesel (3.00 / 0) (#19)
by nothing to lose (nothingtolose175 at yahoo.com) on Sun May 22nd, 2005 at 06:11:15 AM MST
"How about machining yuor own injector and preheating the oil just before it goes into the manifold?
I think it would work but the plugs might not last long."
I am thinking about the same for a truck engine, 351W 3/4ton :)
Heat the oil at the exhaust manifold, pipe to injector at the carb. Used feul injectors cost me $3 each. Have to figure a way to fire the injectors still though.
I figure if I back off the gas (run very lean) and inject the WVO, the gas should fire and help burn the WVO. I have the feul pump and injectors, did not have oil, getting it today.
Hopefully today, lots of thunder just started up here :(
Biodiesel | 25 comments (25 topical, 0 editorial)
