"How about machining yuor own injector and preheating the oil just before it goes into the manifold?
I think it would work but the plugs might not last long."
I am thinking about the same for a truck engine, 351W 3/4ton :)
Heat the oil at the exhaust manifold, pipe to injector at the carb. Used feul injectors cost me $3 each. Have to figure a way to fire the injectors still though.
I figure if I back off the gas (run very lean) and inject the WVO, the gas should fire and help burn the WVO. I have the feul pump and injectors, did not have oil, getting it today.
Hopefully today, lots of thunder just started up here :(
