need 48vdc to 12 vdc converter | 14 comments (14 topical, editorial)
Re: need 48vdc to 12 vdc converter (3.00 / 0) (#7)
by joelhacker (joel dot hacker at motorola dot com) on Thu Jun 23rd, 2005 at 10:50:43 AM MST
If you are going to run multiple converters in parallel, you must use
resistors on the output of each side of the positive terminal so small
differences in their regulators don't drive eachother batty and one
regulator which is tweaked for a slightly higher voltage doesn't wind
up trying to pull up the other converters while their regulators tries
to pull the high one down, and slowly one-by-one your bank of converters
kills each other off (of at least constantly blowing all the fuses).
need 48vdc to 12 vdc converter | 14 comments (14 topical, 0 editorial)
