But it seems like they both would have to be bad to only have 0.8VACopen. Right?[ Parent ]
Shorted turns in both coils would be unlikely, but you could apply a low ac voltage and measure the current in each coil. Shorted turns don't have much effect on dc resistance but they show up on ac.
Difficult to have any other ideas without actually seeing the thing. Let us know what you find.
Flux[ Parent ]
I did not know that! I will add that to the list of things to check.
Thanks, G-[ Parent ]
When I check AC amps into the coils at low voltage, I'll check DC amps and field strength also.[ Parent ]
I think it would be an excelent beginners project for many reasons. I will post pic's and the story when it is finished. Thanks, G- [ Parent ]
If the coils are from the original winding they may be faulty with shorted turns, I assumed that you had wound them recently.
If you prove these coils to be faulty and wish to use it with the 2 good pairs, you will do better to remove the dead coils completely, they will absorb power.
"New Idea Makes Box Fan Conversion Very Easy"
http://www.fieldlines.com/story/2005/7/4/34446/17324
Thanks a million!
G-[ Parent ]
http://www.fieldlines.com/story/2003/12/30/143548/79 W o o f -={([ Parent ]
Also the least expensive. Just adding 4 neos, output wire, 3 bridges, solder, and hot glue. (not sure how good of an idea hot glue is on the coils)
No fancy machining either. Could buy ALL the tools I used brand new for $12, including the meter!
A little 'outside the box', but kind of an obvious idea after you see a couple pic's.
G- [ Parent ]
