Strange Coil Troubles | 16 comments (16 topical, editorial)
Re: Strange Coil Troubles (3.00 / 0) (#5)
by hiker (hiker.wild[at]yahoo[dot]com) on Tue Jun 28th, 2005 at 02:56:14 PM MST
hook a batt. or batt. charger to the coils in question--then hold a mag in your hand over the coils--is the stringht the same on all three coils--as far as the attraction or repulsion..if theirs a weak one it will have less power [push- pull]..may be shorted windings or shorted to lams..to check to see if its shorted out to lams --just hook up one coil output wire to batt. then touch the other batt. lead to the lams --if theres a short you should see a spark....or just use a ohms meter the same way..
WILD IN ALASKA
Re: Strange Coil Troubles (3.00 / 0) (#7)
by ghurd on Wed Jun 29th, 2005 at 07:54:42 AM MST
I checked all 3 pairs with an ohm meter and got no reading to the lams. Or to other coil pairs.
When I check AC amps into the coils at low voltage, I'll check DC amps and field strength also.
Strange Coil Troubles | 16 comments (16 topical, 0 editorial)
