Strange Coil Troubles | 16 comments (16 topical, 0 editorial)
Re: Strange Coil Troubles (3.00 / 0) (#6)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Tue Jun 28th, 2005 at 03:54:57 PM MST
You pretty much coverd this when you reversed the connections of the 2 coils in the set. But it is likely that you have a coil reversed, mounted with a clockwise twist and not counter-clockwise or visa-versa.
W o o f -={(
Re: Strange Coil Troubles (3.00 / 0) (#8)
by ghurd on Wed Jun 29th, 2005 at 08:04:41 AM MST
Switching them 3 times should have got it right at least once.  I hope!
( But I have done dumber things.
Yesterday, changing the wire on that PV that got hit by lightning...
Big hurry, starting to storm. Rush, rush, rush.
Ran the wire backwards from the controller to the PV.  Cut the wire.
Connected the wire to the PV. Solder, anti-corrosion grease, sealed the box...
I connected the PV to the dang spool of wire, not the controller wire! LOL!
But at least I got it right on the second try! )
