Strange Coil Troubles | 16 comments (16 topical, 0 editorial)
Re: Strange Coil Troubles (3.00 / 0) (#9)
by ghurd on Wed Jun 29th, 2005 at 08:16:52 AM MST
Flux,
I should have mentioned this is that unusual lay out conversion we talked about a month or 2 ago.
With 6 factory coils and 4 magnets. No cogging. No rewind.
I'll call it a success even if one pair does not work.
Maybe that's why it was in the trash?
I think it would be an excelent beginners project for many reasons.
I will post pic's and the story when it is finished.
Thanks,
Re: Strange Coil Troubles (3.00 / 0) (#10)
by Flux on Wed Jun 29th, 2005 at 11:08:01 AM MST
Thanks, I have had a look at the original post. There is absolutely no reason why one pair of coils shouldn't work, the whole thing is symmetrical.
If the coils are from the original winding they may be faulty with shorted turns, I assumed that you had wound them recently.
If you prove these coils to be faulty and wish to use it with the 2 good pairs, you will do better to remove the dead coils completely, they will absorb power.
Re: Strange Coil Troubles (3.00 / 0) (#11)
by ghurd on Wed Jun 29th, 2005 at 11:29:18 AM MST
Its here,
http://www.fieldlines.com/story/2005/5/4/15729/16162
Re: Strange Coil Troubles (3.00 / 0) (#16)
by ghurd on Sun Jul 3rd, 2005 at 09:49:36 PM MST
The story and photos are up.
"New Idea Makes Box Fan Conversion Very Easy"
http://www.fieldlines.com/story/2005/7/4/34446/17324
Thanks a million!
Re: Strange Coil Troubles (3.00 / 0) (#12)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Wed Jun 29th, 2005 at 10:15:52 PM MST
many have tried and failed to make a generator out of a 20" window fan motor.
http://www.fieldlines.com/story/2003/12/30/143548/79
W o o f -={(
Re: Strange Coil Troubles (3.00 / 0) (#13)
by ghurd on Thu Jun 30th, 2005 at 03:24:29 AM MST
LOL!
I have to call this my biggest success!
With 0.6A x 3 = 1.8A into a battery.
(thats if the 3rd one works)
Also the least expensive.
Just adding 4 neos, output wire, 3 bridges, solder, and hot glue.
(not sure how good of an idea hot glue is on the coils)
No fancy machining either.
Could buy ALL the tools I used brand new for $12, including the meter!
A little 'outside the box', but kind of an obvious idea after you see a couple pic's.
