I think its a good idea.
However There are some pro's and con's...
DISADAVANTAGES-
Regardless of high impeadance coolant utilized(for heat transfer removal) there will most certainly have to be a positive displacement electric pump utilized, this means possible amperage req's [exceedance] that such a stator could produce in the first place.
This forced circulation type of methodology would be akin/relative to direct losses commonly associated with energizing "field windings" as such, auto alternators, dont make a good candidate(for wind genny's), but most likely, the same type of parasitic losses from forced cooling (dcvolt pumping)loads would be 10 times worse than any field energization scnario... THIS IS ESPECIALLY TRUE WITH 1/8 COPPER TUBE WINDINGS.
most likely one would do better with high dielectric stregth (linseed)oil forced circulation to the outside of multi-strand windings,in the stator, with a phased zone circulation high flow convection circuit with some sort of raditaor.
Advantages-
The pumping load/force to be applyied to the forced cooling system could be derived from the mill blades itself...
This wouldnt be necessary in the first place, because(sp?) most windmill's dont rotate fast enough to induce hugh hysteriious losses in there stators's/windings.
However, "if" you were driving a load such as a motor does, this forced cooling methodolgy would make sense if the stator were driving such an electric motor. But quite frankly i think its a major overkill on any type of dual rotor type of windmill.
I have developed a 600amp continious solid state "DC" three phase switching array triggered by 6000hz pick ups modulated to operate with a fixed stator.
Im wondering if the standard 1x2x1/2in rectangular[neo] blocks can be procured with 2 separate 1/4in holes cut by water jet, in a centerish position...........
JW
