FL inverter | 26 comments (26 topical, editorial)
Re: FL inverter (3.00 / 0) (#1)
by jacquesm (j@ww.com- I run a whitelist, add 'stjoes' to msg) on Fri Jun 3rd, 2005 at 10:45:00 AM MST
(User Info) http://www.greenbits.com/
that's so small you might actually be able to get it hidden away in the lamp socket... does it get warm ?
www.greenbits.com
Re: FL inverter (3.00 / 0) (#2)
by commanda (alwynne at unwired dot com dot au) on Fri Jun 3rd, 2005 at 04:18:21 PM MST
Running the 15 watt tube, with the mosfet on a heatsink, is only a couple of degrees temperature rise. Got to run it for a while with no heatsink and measure the temp.
Might xmas tree it onto a small flat piece of aluminium to act as a small heatsink, and physically hold it together.
I've also got some 4foot tubes; got to test with them yet also.
FL inverter | 26 comments (26 topical, 0 editorial)
