How often do You clean your solar pannels | 15 comments (15 topical, 0 editorial)
Re: How often do You clean your solar pannels (3.00 / 0) (#6)
by Ungrounded Lightning Rod on Thu Jun 9th, 2005 at 01:42:25 PM MST
Unless you live in an area with some special problem, it could be argued that, if you need to clean your panels more than once or twice a year, you didn't install enough panels.
When the cost of your time cleaning panels and the shortened life of your batteries exceeds the cost of more panels, add one or two.  Then kick back, relax, and check whether they need cleaning whenever you go on/off daylight savings time.  B-)
But seriously:  Check whether they need cleaning whenever the batteries aren't staying full.  Then, if there's no special problem (like a dust storm, tree pollen, soot from an upwind stack, leaves / pine needles, or a snowdrift) and your batteries and distribution system are OK, add more panels or reduce loads until your batteries stay up without constant attention and cleaning.
Re: How often do You clean your solar pannels (3.00 / 0) (#7)
by ghurd on Thu Jun 9th, 2005 at 01:58:11 PM MST
Excellent point!
I think most of the smaller ones are cleaned for cosmetic purposes.
Also,
Sandovalach's system is nearer the equator and mounted very flat compared to most areas.
His will hold dust and grime more than most areas.
Re: How often do You clean your solar pannels (3.00 / 0) (#8)
by sandovalch (sandovalch@yahoo.com) on Thu Jun 9th, 2005 at 03:08:36 PM MST
Well, that is true. In my location at this time of year they "should" be near parallel to the ground, but where would the water and dust go, since I have an aluminum frame around them?
In commercial panels you have another kind of material covering the cells, I used standard glass.
Re: How often do You clean your solar pannels (3.00 / 0) (#9)
by Ungrounded Lightning Rod on Thu Jun 9th, 2005 at 07:43:49 PM MST
Build a box that's mainly a slanted glass (or whatever) plate over them and let the rain wash the dirt off THAT.
(If you enclose the panels in a box with a transparent top be sure to vent it a bit near its high point to let the heat out, so the panels can cool.  But not enough to let a bunch of dirt in and defeat the purpose.)
Re: How often do You clean your solar pannels (3.00 / 0) (#10)
by troy on Fri Jun 10th, 2005 at 11:24:07 AM MST
Actually, if you build a "box" around them with glass over the top to "protect" them, you just guaranteed yourself a 5-10% drop in output forever.  Normal glass loses about 4% in reflection losses at each optical surface.  I'd prefer a little dirt once in a while that I can hose off.
Finest regards,
troy
Re: How often do You clean your solar pannels (3.00 / 0) (#11)
by Ungrounded Lightning Rod on Fri Jun 10th, 2005 at 06:23:12 PM MST
True.
But if the panels are near horizontal, collecting dirt, leaves, and small growing things, they could be losing a LOT more than 5-10% without cleaning at very short intervals.
If it were me I'd buy 11 panels instad of 10, put the glass up, and relax for six months to six years at a time.
The whole POINT of things like electrical power is so YOU don't have to be doing a lot of work - like scrubbing stuff - using your own manual labor.
