How often do You clean your solar pannels | 15 comments (15 topical, editorial)
Re: How often do You clean your solar pannels (3.00 / 0) (#9)
by Ungrounded Lightning Rod on Thu Jun 9th, 2005 at 07:43:49 PM MST
Build a box that's mainly a slanted glass (or whatever) plate over them and let the rain wash the dirt off THAT.
(If you enclose the panels in a box with a transparent top be sure to vent it a bit near its high point to let the heat out, so the panels can cool.  But not enough to let a bunch of dirt in and defeat the purpose.)
Re: How often do You clean your solar pannels (3.00 / 0) (#10)
by troy on Fri Jun 10th, 2005 at 11:24:07 AM MST
Actually, if you build a "box" around them with glass over the top to "protect" them, you just guaranteed yourself a 5-10% drop in output forever.  Normal glass loses about 4% in reflection losses at each optical surface.  I'd prefer a little dirt once in a while that I can hose off.
Finest regards,
troy
Re: How often do You clean your solar pannels (3.00 / 0) (#11)
by Ungrounded Lightning Rod on Fri Jun 10th, 2005 at 06:23:12 PM MST
True.
But if the panels are near horizontal, collecting dirt, leaves, and small growing things, they could be losing a LOT more than 5-10% without cleaning at very short intervals.
If it were me I'd buy 11 panels instad of 10, put the glass up, and relax for six months to six years at a time.
The whole POINT of things like electrical power is so YOU don't have to be doing a lot of work - like scrubbing stuff - using your own manual labor.
How often do You clean your solar pannels | 15 comments (15 topical, 0 editorial)
