New Darrieus Turbine | 31 comments (31 topical)
Re: New Darrieus Turbine (3.00 / 0) (#12)
by armidalian on Sun Jul 17, 2005 at 11:25:03 PM MST
Hmmm, an interesting idea. Perhaps rather than a spring a rubber suspension bush would do the job better - it will absorb the immediate stresses without resonating too badly. I also envisage that the main struts would be of high-tensile steel (I was thinking threaded bar but probably unthreaded would be stronger and probably cheaper). Also bracing with steel cable - all these belts and braces should make sure that the blades stay on without too much parasitic drag... and if they do disintegrate it should fail in a contained manner - with the blade fragments retained rather than fly apart. At least that would be a goal.
personally i think there are better vawt designs
Such as...? At this stage I'm open to all ideas.
Re: New Darrieus Turbine (3.00 / 0) (#13)
by bob golding on Mon Jul 18, 2005 at 04:04:40 AM MST
have a look at vawt's on the uspto website lots of  designs there. think the advantage of vawt's is lots of torque at low speed. i suspect  when you start  trying to design a high speed vawt the advantages over a hawt diminisish. there is probably a sweet spot around 500/800 rpm i suspect. go much faster than that and balance and fatigue problems start to come up. i have all the bits to make a  green windmill. looks like a good design and it is commercially available which is a good sign. always interested in  new vawt designs . keep us informed of progress. good luck.
bob golding
