Since the threading is left handed, I am making my turbine blades run counter clock wise.. Or if you plan on running purchased blades, you could probably run a downwind setup.
One worry is that the motors have brushes that will eventually wear out. Since this is my first generator and I still want to experiment, I see this motor as a temporary solution. [ Parent ]
