elevated weight as storage for generator? | 26 comments (26 topical, editorial)
Re: elevated weight as storage for generator? (3.00 / 0) (#18)
by benjamindees (fieldBLAHlines@deesconsulting.com (remove BLAH)) on Fri Sep 16th, 2005 at 08:19:06 PM MST
(User Info) http://www.deesconsulting.com
Good point.  But you're off by an order of magnitude.
 100,000 gallons raised an average of 75 ft is:
 100,000 * 8.3 lbs * 32 ft/s^2 * 75 ft = 1,992,000,000 lb*ft^2/s^2 = 23.3 kWh
That's equivalent to about 17 220 Ah, 6 volt batteries, which, new, are anywhere from $75-$100 each.  Assuming you only discharge them halfway, that makes 35 batteries, which is like $2600, not including shipping.
Your point is still valid but, at the same time, for some people it may really be easier or more beneficial to build a storage tank on top of a hill than to purchase batteries.
elevated weight as storage for generator? | 26 comments (26 topical, 0 editorial)
