elevated weight as storage for generator? | 26 comments (26 topical, editorial)
Re: elevated weight as storage for generator? (3.00 / 0) (#20)
by Bullsup (pcw@colinbull.org.uk) on Tue Oct 25th, 2005 at 05:49:42 PM MST
(User Info) http://www/colinbull.org.uk
I found this site by accident doing some research for a biofuel project but found it rather appropriate.
I live 10 metres from the sea about 5 metres above sea level. At the top of the field behind my house is an empty WWII fuel storage tank that I reckon holds 50,000 tons at about 110 metres above sea level.
So I calculate that 105 ( metres) x 50,000 (tons) x 9810 ( joules) = 51,000 MJ is the potential storage. How many Kwh is that ?
Colin Bull
Re: elevated weight as storage for generator? (3.00 / 0) (#21)
by benjamindees (fieldBLAHlines@deesconsulting.com (remove BLAH)) on Tue Oct 25th, 2005 at 07:41:38 PM MST
(User Info) http://www.deesconsulting.com
Welcome to the site! That's quite a setup you've got! 50,000 tons is almost 13 million gallons of water!
I don't understand your calculation, but you came to the right answer, which is all that's important. You can convert between any of these units at www.convertit.com. I get about 12974 kWh. Of course you will have conversion losses in making use of this energy, and water turbine efficiencies can range from 30%-90%. But even at 30% efficiency, that's enough storage to power an average home for 7.5 months! Good luck and I hope you keep us updated!
elevated weight as storage for generator? | 26 comments (26 topical, 0 editorial)
