I've been thinking of creating a micro-hydro undershoot wheel that runs a mechanical air pump that feeds into a tank. I then use the air power to run a basement sump pump.
Typical Sump: 2 meter lift average 400 liters per day (800 liter/meters per day)
Typical Stream Flow: 1 liters/second (min=0 max=25 L/sec) Stream Head Drop: 20 cm
Could you figure out a way to get a shaft from the microhydro to the basement pump? After all, the high rainfall that'll flood your basement is also the high rainfall that'll speed up your stream. [ Parent ]
