Wind Generator with Hard Drive Magnets | 44 comments (44 topical, 0 editorial)
Re: Wind Generator with Hard Drive Magnets (3.00 / 0) (#11)
by Ungrounded Lightning Rod on Sat Sep 24th, 2005 at 09:38:39 PM MST
Instead of breaking the magnets in half, why not just lay them out along the circumference of your rotors?
Space them maybe a fifth of their length apart as you go around the circumference (1 unit gap, 2 units north pole, 1 unit effective gap in the middle of the magnet, two units south pole).  You'll have more poles for a given radius - which is GOOD.  Rasies your frequency and the voltage (because the effective risetime of the field is shorter), lowers your cutin speed.  The polarity of the magnets comes out right for a dual-rotor if you position them so the bodies of the magnets are opposite each other.
Expand your radius and use still more magnets for more power, or to let you use more and thinner coils so the gap can be reduced and the field strength increased.
Re: Wind Generator with Hard Drive Magnets (3.00 / 0) (#41)
by duden (mprism@ntlworld.com) on Thu Dec 29th, 2005 at 10:28:47 AM MST
(User Info) http://frenchstudio.co.uk
Further to your idea about using complete magnets, what about using the magnets in pairs. If you connect N-S, N-S in that order you will get a larger magnet. If you then double the diameter of the rotor, you should get a lower revving generator for a given output voltage. The coils can also be better matched to the size of the magnets.
It will be necessary to double or treble the number of magets thickness wise so you obviously need a lot of drives.
