the hub (the part with the splined hole and the 5 wheel studs) is only pressed into the outer bearing, and the spindle mounting flange (three bolt circle) is dropped over that, and then the inner bearing is pressed onto the hub from the inside. you need something serious in tension, with big flanges inside that splined hole, to keep the bearings from sliding off the hub.
allan[ Parent ]
