Vawt Darrieus questions | 22 comments (22 topical)
Re: Vawt Darrieus questions (3.00 / 0) (#12)
by vawtman on Fri Jan 20, 2006 at 06:26:46 PM MST
Anthony would you please stop bringing up your powerless decorations on posts where people are learning and testing methods to make power.Its starting to get annoying.You prabably thrive on the attention you get allthough negative for some reason.PLEASE
Re: Vawt Darrieus questions (3.00 / 0) (#13)
by TomW on Fri Jan 20, 2006 at 06:51:34 PM MST
vawtman;
Ahem, good point. Tony seems unable to distinguish between spinning free and power extraction.
I, too, believe he is just trolling for attention and maybe website hits. The waters here must be fertile.  Being a completely open and free resource run by very friendly folks, I guess we have to see it continue. Sad really because I am sure it confuses folks who can't tell fact from fiction.
Without fools, you could not look intelligent. There is no knowledge without questions.
Re: Vawt Darrieus questions (3.00 / 0) (#14)
by vawtman on Fri Jan 20, 2006 at 06:53:40 PM MST
Thanks Tom
Re: Vawt Darrieus questions (3.00 / 0) (#15)
by IntegEner on Fri Jan 20, 2006 at 08:49:56 PM MST
I made my points and will let this rest. Let's see if any drawings materialize. The writer of this post will be pleased with what I have offered as time unfolds. The guys up in Montana with Energy Transfer Corporation were displeased with the mediocre attention given to their project. The fact of the verticals blade swept areas needing to be 1.5 times larger than the horizontals blade swept areas for the same power production capacity needs more technical understanding and popular recognition. Thanks, though, for the replies and I don't have a care about anything but just being a good, decent guy.
Anthony C.
IntegEner-Wind
Tehachapi, CA (where we have thousands of power producing wind turbines for the utilities and even a few dozen for homeowners and businesses)
www.integener.com
Re: Vawt Darrieus questions (3.00 / 0) (#16)
by vawtman on Sat Jan 21, 2006 at 09:34:14 AM MST
Thanks Anthony.
Re: Vawt Darrieus questions (3.00 / 0) (#17)
by IntegEner on Sun Jan 22, 2006 at 06:44:20 AM MST
Fine. This does not mean anything but that the verticals need better understanding. It seems to be something waiting for the right touch. I have always been surprised at how their reputation has been scarred by earlier problems that have no impact on the basic ideas of how they work.
Anthony C.
www.integener.com
Re: Vawt Darrieus questions (3.00 / 0) (#18)
by wdyasq on Sun Jan 22, 2006 at 11:27:18 AM MST
"This does not mean anything but that the verticals need better understanding.'
Maybe we should give the laws of physics a government check, make them go to a sensitivity camp and put them in government housing.  Maybe they will understand then.
Re: Vawt Darrieus questions (3.00 / 0) (#20)
by IntegEner on Sun Jan 22, 2006 at 02:39:27 PM MST
Even the Lift Principle itself. Add that to the pot. My "attitude" must really show. Maybe I should get on IRC about these things.
Anthony C.
www.integener.com
Re: Vawt Darrieus questions (3.00 / 0) (#21)
by IntegEner on Sun Jan 22, 2006 at 04:14:55 PM MST
Here are a few images of the small verticals that was made up as a kit. This design has been proving itself to be something worth continuing and performs substantially better than earlier attempts based on more conventional style blades approximating NACA 0018. These blades are made from 4 inch (10 cm) aluminum roof flashing sheet from local hardware stores that has a folded leading edge to a 1/4 inch diameter with some creases added lengthwise along its chord. Otherwise it is just as thin as it comes off the 50 foot long rolls that I take home. The gap between the blade pairs can be seen in the third image. Some steel sheet was added for reinforcement plate at the mountings to the rotor arms and can be seen also.
This blade design was no accident. It was arrived at in maximizing the airflow deflection that results in the blade driving force, otherwise known as "lift", and minimizing the profile drag. The string that can be seen in the corner of the photos was there to keep the rotor from starting up while the photo was taken. Startup is not a problem here and it will even start against a load. Other views I have posted show the blades running at high speeds similar to the small horizontals. It lights the LED lights from its direct coupled axial flux generator. Unlike the Savoniuses, this can be readily scaled up both in blade length and rotor arm diameter.
(Only one blade pair is fully assembled while the other three were just hung on their arms for the photo.)
No one has ever claimed that blades like this have been tried anywhere else to my knowledge. Most everyone seems to feel they don't work until they see it start up and run.
Anthony C.
www.integener.com
