Surf board like blades , revisited | 37 comments (37 topical)
Re: Surf board like blades , revisited (3.00 / 0) (#5)
by nothing to lose on Wed Feb 01, 2006 at 04:59:27 AM MST
I see what you are doing, though it's not what I first thought you meant.
So your not cutting an entire blade out of foam then laminating the blade with fiberglass? Instead it looks like your building a hollow blade with spars like an airplane wing, is that right? The Arrow and the fiberglass mat are all that's running the length of the blade then?
My thought was that you were carving the blade out of a sheet of insulation same as carving one out of wood. I will try that later.
I been wanting to build a surfboard type sail boat this way. Laminate the insulations together and cover with fiberglass. I think it would be fun to take to Canada next trip for on the Montreal river and others. I have not had time to build it though. Sort of a cross between canoe, Kayac, and sail boat. With a small trolling motor for no winds or up stream power.
Foam can be very strong itself when thick or covered, and it's very light weight.
Re: Surf board like blades , revisited (3.00 / 0) (#6)
by willib on Wed Feb 01, 2006 at 07:17:55 AM MST
Origionally i was going to carve the whole blade out of one (or two)long pieces of insulation, yes , But , now i am going to use this approach..because it has some advantages over the other meathod.
one being , i can move the sections in any angle i want.since they are not fixed to the spar yet.
 i can easily make as many sections as needed.
i can glue the sections together when i am happy with their position.
lastly it looks really cool. and is so simple to do..
Carpe Ventum (seize the wind)
Re: Surf board like blades , revisited (3.00 / 0) (#7)
by BigBreaker on Wed Feb 01, 2006 at 08:57:07 AM MST
You could make several metal forms like a cookie cutter representing the cross section in various places.
Heat those cutters up with a torch and use them to perfect cross sections in the foam sheet.
With that techique you could use a lot more foam "ribs" on each spar and make nice skeleton for fiberglass.  It would also make the construction process very repeatable.
Alternatively you could have cross sections jet cut out of aluminum and use a hot wire to cut using the sluminum as the pattern.
Re: Surf board like blades , revisited (3.00 / 0) (#20)
by willib on Fri Feb 03, 2006 at 02:49:33 PM MST
also a good idea !
with enough Al cross-sections , of the right size , that would be the way to go..
Re: Surf board like blades , revisited (3.00 / 0) (#9)
by Chagrin on Wed Feb 01, 2006 at 11:46:58 AM MST
Now that I see your construction I can understand the advantages of doing things this way, but in the end it's not going to work. With repetitive stress, your stiff carbon spar is going to loosen the holes in the foam due to its comparative stiffness to the fiberglass and eventually the fiberglass will crease/buckle with nothing to back it up.
