You can make the cutter from some dorbell transformers, and a dimmer switch. You have to get a special kind of wire to run, like is found inside of hair dryers, and electric heaters. Just be carefull that you get the biggest dimmer switch you can find, cause they can get overloaded easy."Don't worry about tomorrow, plan for it."
Definitely superior to steel wire, though.[ Parent ]
