Blade Speed | 14 comments (14 topical)
Re: Blade Speed (3.00 / 0) (#13)
by finnsawyer on Sat Jan 14, 2006 at 10:14:17 AM MST
Well, I try to be helpful.  One purpose of this site is the exchange of ideas.  If it appears someone is going down a blind alley, shouldn't we call that to their attention?  Some people tend to poo-poo the years of dedicated scientific research that has gone on before.  Others refuse to try to make basic measurements (the Bedini Controvery), and others just don't know how (the Pergomotor Saga).  Why shouldn't we make an effort to help them avoid wasting years of their life pursuing what amounts to a dead end.
I also can learn things and develop insights based on these little discussions.  I hadn't given much thought to the deflection of the air by propellers, fans, or airplane wings.  It just didn't seem to have any relevance to the behavior of wind mill blades.  Since you thought that it was important, I conceived of a specialized experiment consisting of a long tube shaped wind tunnel with the windmill occupying essentially the entire diameter of the tube.  This eliminates any vortices off of the tip.  There are two possible directions for the air flow behind the blades; straight back, or tangential to the side of the tube.  The latter flow will constitute a vortex and will quickly dissipate against the side of the tube.  The problem is, that it may not exist.  Just because something could be there doesn't mean it has to be there.  Nature has a way of confounding our expectations.  If it doesn't exist your theory, whatever its merits, will have no relevance to the behavior of a horizontal axis windmill.  If it does, the resulting expanding vortex will affect the placement of wind mills in a wind farm.  Perhaps your first proposal should deal with this issue.  Maybe I'll do it myself.  What is the name of the the foundation involved?  I could use a wind tunnel.
GeoM
Re: Blade Speed (3.00 / 0) (#14)
by IntegEner on Sun Jan 15, 2006 at 07:21:38 AM MST
It is the state, the State of California in the States. I am just poor, crazy Knucks, the "church mouse in a poke" as my nickname undergoes further adjustments.
Anthony Chessick
IntegEner-W
Tehachapi, CA
www.integener.com
