The above was my back handed way of saying that the blades on these turbines deserve to be designed well. These high TSRs demand careful work. If anyone wants to see high TSRs take a look at the megawatt-plus turbines.
I honestly don't think that wind energy has answered for itself many of the questions that are being asked not only here but everywhere else as well. The drawn out, patient explanations just aren't holding water. Ask anyone.
I have put together a few wind rotators using ideas that seem to me to be valid and they work quite well on their small scale as are shown in images on the IntegEner-W website. I think I have both recognized good approaches taken by others and taken some worthwhile first steps myself in finding approaches that stress good blade design. Replies welcome but not necessary.
Anthony Chessick www.integener.com [ Parent ]
Anthony Chessick IntegEner-W www.integener.com [ Parent ]
As far as drag is concerned, all modern air foils are low drag. The problem comes about for a high speed horizontal axis windmill, because only a very small fraction of the lift gets converted to usable torque. This has the effect of amplifying the drag effects relative to what you would find for an airplane wing. Since lift goes as the apparent wind speed cubed and drag as the apparent wind speed squared, one is probably still better off using a high value of TSR. A higher TSR also means the alternator turns faster giving better performance there.
You can study the aerodynamics of windmills until Hell freezes over, but, until you actually build a complete system and show that its performance is superior to anything available you are just howling in the wind. GeoM[ Parent ]
I also can learn things and develop insights based on these little discussions. I hadn't given much thought to the deflection of the air by propellers, fans, or airplane wings. It just didn't seem to have any relevance to the behavior of wind mill blades. Since you thought that it was important, I conceived of a specialized experiment consisting of a long tube shaped wind tunnel with the windmill occupying essentially the entire diameter of the tube. This eliminates any vortices off of the tip. There are two possible directions for the air flow behind the blades; straight back, or tangential to the side of the tube. The latter flow will constitute a vortex and will quickly dissipate against the side of the tube. The problem is, that it may not exist. Just because something could be there doesn't mean it has to be there. Nature has a way of confounding our expectations. If it doesn't exist your theory, whatever its merits, will have no relevance to the behavior of a horizontal axis windmill. If it does, the resulting expanding vortex will affect the placement of wind mills in a wind farm. Perhaps your first proposal should deal with this issue. Maybe I'll do it myself. What is the name of the the foundation involved? I could use a wind tunnel. GeoM[ Parent ]
Anthony Chessick IntegEner-W Tehachapi, CA www.integener.com [ Parent ]
