24 VOLT INVERTER | 16 comments (16 topical, editorial)
Re: 24 VOLT INVERTER (3.00 / 0) (#2)
by Titantornado on Tue Dec 5th, 2006 at 10:53:36 AM MST
If what they say about active waveform is true, that's a good price for what basically amounts to an efficient, true sinewave inverter.  Being stackable only makes it that much better of a deal.  Buy what you can afford as you go. Being able to make a 220/110 arangement is neat too, but I don't think appliances that use both will work. (most 220v ranges and dryers have a neutral) Not that you should be using such appliances in your inverter driven home.
I like them, but I'd like to hear a little more about the efficiency curve.
Rod
24 VOLT INVERTER | 16 comments (16 topical, 0 editorial)
