Box Fan Motor Conversion | 17 comments (17 topical, editorial)
Re: Box Fan Motor Conversion (3.00 / 0) (#16)
by ghurd on Wed Feb 22nd, 2006 at 07:59:45 AM MST
Zap,
Was the 96 turns, 3 in hand, for all 3 wires?  I mean was the green wire less turns?
Going from 300 turns to 400 turns, and wired in star, cut in should be ~130 RPMs. I think.
Re: Box Fan Motor Conversion (3.00 / 0) (#17)
by zap (bell47g5a at comcast dot net) on Wed Feb 22nd, 2006 at 11:17:46 AM MST
G- on the coil I unwound all the wires stayed neck and neck, they all had the same number of turns, which is why I referred to them as "3 in hand".  The only reason I unwound that one was because I'd cut it's leads a little short at where the "buried ends" come out from under the rest of the coil.  It left very little exposed for further hook up.
zap
Box Fan Motor Conversion | 17 comments (17 topical, 0 editorial)
