Tracker on the cheap | 18 comments (18 topical, editorial)
Re: Tracker on the cheap (3.00 / 0) (#12)
by Volvo farmer on Tue Mar 7th, 2006 at 06:33:45 PM MST
20% was a number I pulled out of the air based on some things I've heard. I don't know that I'll ever be able to measure the true difference. These batteries just sit there on float 95% of the time and I have no device for measuring my amps in/out on this little system.
I'm preparing to fly a 680 watt array with a similar setup. It might be possible in a year or so for me to compare fixed vs. tracked on the bigger system but it won't be for quite a while.
I haven't thought much about heat in the jar. Hmmm, maybe I should. The nice thing is if I burn the tracker up, it's only a $35 lesson.
I was out yesterday and today and the thing was pointed exactly at the sun every time I looked at it. It works flawlessly so far. Maybe I'll disable it for a while since I'm not using a single watt of that electricity I'm making.
Now I'm dreaming on how I could use the heat from a solar concentrator. I've got two very nice eight foot aluminum dishes laying around here.
Volvo Farmer
Re: Tracker on the cheap (3.00 / 0) (#13)
by ghurd on Tue Mar 7th, 2006 at 07:15:59 PM MST
The 20% seems low for what I read.  Never did it.  And couldn't measure it either.
Not sure about the heat build up.
"not using a single watt"
Maybe Ed's style simple shunt to a dump heater?
Like 160W, x 5 hours, x 150%.  Thats like a space heater for 1 hour a day.
Maybe a 12V CFL or 2 from a single wire from the batteries?
In the most used lamps in the house.
Maybe charge the cell phones, LED lights, and drill batteries?
Thats mostly what I do with my wind power.  :-/
Feels nice just the same.
Tracker on the cheap | 18 comments (18 topical, 0 editorial)
