An Alternate PM Alternator Design | 50 comments (50 topical)
Re: An Alternate PM Alternator Design (3.00 / 0) (#25)
by finnsawyer on Wed Apr 26, 2006 at 10:09:55 AM MST
There are two things that make or break an alternator design.  Firstly, you need to get the proper voltage at the cut-in speed.  This depends on the number of turns (note turns, you can't make an alternator with only radial wires) and the strength of the magnetic flux.  Larger flux, fewer turns.  That applies to this design as well.  Once you have established the number of turns the second requirement is current carrying ability or resistance.  The solution to lower the resistance is to use heavier wire for the same number of turns.  You now made the coil bigger.  This requires a larger rotor.  That will give a lower cut-in rpm.  That is true for this design as well.  So, for a proper combination of magnet size, wire size, number of turns, and rotor size it should be possible to satisfy the design criteria.  The problem of course is that these things are all interrelated.  It will take while to sort them out.  The design currently used was obtained by trial and error.  I suspect the same will hold true for this one.
GeoM
