An Alternate PM Alternator Design | 50 comments (50 topical, editorial)
Re: An Alternate PM Alternator Design (3.00 / 0) (#26)
by SmoggyTurnip on Wed Apr 26th, 2006 at 11:39:41 AM MST
"While it is true that each voltage pulse will have a value proportional to the rpm, they have different values.  One is two thirds the peak voltage, the other one third.  They will cause conduction in turn as the rpm increases."
Yes, I agree they will each increase at different rates but they will
each be with the square of RPM.
Coil1 = K1*RPM^2
Coil2 = K2*RPM^2
Coil1+coil2 = (K1+K2)*RPM^2 = K*RPM^2
So in the end the power curve is with the
square of the RPM.  This means it can
be reproduced by another dual rotor machine
of standard design.
"A little elaboration on matching curves may help.  The general curve for a cubic is:  P = AxV^3 + BxV^2 + CxV + D.  In this D = 0."
Yes this is true - the power in the wind follows the cube of wind velocity, but B, V, and D are 0.
As far as the power curve of the blades go we really don't
know the formula for it - it could even be a fourth power,
it really depends on the blades, - one thing we can say is that
it is concave down everywhere.
In matching the alternator to the blades the 2 curves that have
to intersect are :
 1) the alternator power verses RPM and
 2) blade power at the shaft verses RPM.
The blade power curve is concave
down everywhere and the alternator
power curve is K*PRM^2. They
can only intersect at 2 places
- one of them being (0,0).
The sooner you start the longer it takes.
Re: An Alternate PM Alternator Design (3.00 / 0) (#27)
by finnsawyer on Thu Apr 27th, 2006 at 08:23:15 AM MST
A short response.  Power into the battery is proportional to current.  Current is charge per unit time.  As the rpm goes up you dump more charge per unit time into the battery after each break point.  A regular alternator doesn't do that.  By the way, when a regular alternator is charging a battery the current is equal to the alternator voltage minus the battery voltage divided by the alternator resistance.  Power into the battery is that current times the battery voltage.  It goes up linearly with rpm.
GeoM
Re: An Alternate PM Alternator Design (3.00 / 0) (#28)
by SmoggyTurnip on Thu Apr 27th, 2006 at 10:58:47 AM MST
Sorry finsawyer,  I guess I just don't understand
what you are saying.  I must be missing something
here.  I don't see where these "break points"
are. I am not saying you are wrong - I just don't
get it.
Re: An Alternate PM Alternator Design (3.00 / 0) (#29)
by finnsawyer on Fri Apr 28th, 2006 at 10:18:27 AM MST
Sometimes it's hard to tell where people are having problems.  Let's try it this way.  When the alternator hits cut-in at let's say 100 rpm, the highest voltage pulse will cause conduction.  I've called this voltage Vp, which varies linearly with rpm.  I'm going to ignore the diode voltage.  So the current that flows from the alternator for the duration of that pulse is:  Ib = (Vp - Vb)/Ra, where Vb is the battery voltage and Ra is the alternator resistance.  I'm also ignoring the battery resistance to keep this simple.  So, the power into the battery is given by VbxIb during the duration of the pulse.  The energy into the battery is given by
Eb = PtxVbxIb = PtxVbx(Vp - Vb)/Ra, where Pt is time duration in seconds of the pulse.  The energy out of the alternator then becomes Ea = PtxVpxIb = PtxVpx(Vp - Vb)/Ra during the pulse.  The percent of energy (or power) going into the battery is given by Eb/Ea = Vb/Vp.  This is the type of behavior you would expect from a regular alternator.
When the alternator hits 150 rpm the second highest pulse becomes large enough to cause the diodes to conduct.  That speed is the first break point.  So now we have a second pulse causing conduction.  Its value is 2/3 that of Vp.  So, for that pulse we may write Ib2 = (2/3xVp - vb)/Ra.  The energy delivered by that pulse is given by Eb2 = PtxVbx(2/3xVp - Vb)/Ra.  The energy from the alternator during that pulse is Ea2 = PtxVpx(2/3xVp - Vb)Ra.  Since both pulses now contribute, we must add their contributions to get the total energy into the battery, which gives:
   Eb = PtxVbx(5/3xVp - 2Vb)/Ra.  Ea = PtxVpx(5/3 - 2Vb)/Ra.
This applies from 150 rpm to 300 rpm.
Finally, when the alternator's speed hits 300 rpm, the second break point, the third pulse will be large enough to cause the diodes to conduct.  This pulse has an amplitude of 1/3 that of Vp.  We now get a current of Ib3 = (1/3xVp - Vb)/Ra, for an energy value of Eb3 = PtxVbx(1/3xVp - Vb)/Ra.  Ea3 = PtxVpx(1/3xVp - Vb)/Ra.  The other two pulses are also contributing so we need to add this to the contributions from the others. We get: Eb = PtxVbx(2xVp - 3xVb)/Ra.  Ea = PtxVpx(2xVp - 3xVb)/Ra.  You get the average power by adding up the energy contributions from all the pulses per cycle (there are two of each) and dividing by the time in seconds per cycle.  These equations show that the rate at which the alternator puts power into the battery as a function of rpm is increased by 2/3 after the first break point and is twice as great after the second break point as its initial value.  This is the basis for the power curve that I gave.
GeoM
Re: An Alternate PM Alternator Design (3.00 / 0) (#30)
by SmoggyTurnip on Fri Apr 28th, 2006 at 10:57:58 AM MST
OK now I get it.
I'm not sure why I didn't get it before,
probably because I'm not used to thinking
about batteries - strictly heating for me
so far.
It is not easy to analyze, but interesting
to think about.
An Alternate PM Alternator Design | 50 comments (50 topical, 0 editorial)
