dual rotor aint broke?
allan
What you see here is the first step in an engineering design, a concept. The next step is to prove it. It is possible that vibration issues may arise. But they are mechanical not electrical. Or actually electromechanical as they involve interactions between the electromagnetic forces and the mechanical vibrational states of the physical structure. If you go back and look at the first set of voltage curves, you will notice that the positive voltage spikes, formed from the addition of pairs of coil outputs are 120 degrees apart in time as are the negative spikes. In other words three phase behavior is embedded in the design. This is a hybrid between single phase and three phase and it will have its own characteristics.
Since this is my diary I'm going to do a bit of ranting here. When scanning the net once for wind power I came across a comment concerning the lack of "anything new in wind power". Back in the 70's when the energy crunch hit everyone was out trying different things. That spirit seems to be gone. Now it's become "cookie cutter" wind power design. I doubt that in twenty years everyone will be doing what you see here. There still are improvements to be made. The dual rotor may not be broke, but then neither was the 36 Ford in 1936. The car you drive today is far different. Things change. You can see why I put this in a diary. I'm not speaking to those who are satisfied with the status quo, but rather those who really want to advance the cause of wind power. Time will tell whether this design has a role to play in that. In any case, it's out there for anyone to try. Just call it the Mattson Alternator, if you will.
I don't want to appear to come down too hard on this site. There is an undercurrent of innovation here, and the discussions are definitely useful. The idea for this design came out of Jerry's "Jerry rigging" of the alternator output. To my mind this is the real power of the Internet. GeoM[ Parent ]
allan[ Parent ]
When you speak of dead wire I presume you are referring to the wire along the top and bottom of each coil. I guess I missed that in your comment, although I was aware of the issue. That wire is there to complete the loop. Every design has to put up with it. To minimize its effect you have the magnet be as large as the inside of the coil. Also make the magnets and coils round. The alternator should still work in that case, but don't expect nice rectangular pulses.GeoM[ Parent ]
just my guess, but it looks like you can get the more power from the same mags and less wire, by going with smaller coils.
allan [ Parent ]
