restless nite | 13 comments (13 topical, editorial)
Re: restless nite (3.00 / 0) (#9)
by johnlm on Sat Apr 22nd, 2006 at 12:06:05 PM MST
Hiker,
Just a thought.  You might get less noise and vibration if you went to 3 blades instead of 4.  4 blades still pose some of the same on and off gyroscopic vibration problems associated with a 2 blade prop.
Johnlm
Re: restless nite (3.00 / 0) (#10)
by hiker (hiker.wild[at]yahoo[dot]com) on Sat Apr 22nd, 2006 at 04:31:52 PM MST
10-4 on that...
i thought i would need the extra power from 4 blades--turns out i don't..
my blades have a good angle at the hub -then i flatin out the leading edge down to the tips[and of course a airfoil shape on backside]makes for a good blade..saved a whole lot of cutting -rasping and sanding..with my angled hub cutouts..the blades were made from 1by4s..
im going to chop off another 3"s from the blades--of course i will have to reshape the
ends of the blades--soon i will have 4 little stubs stickin out if i cut any more. :]
wired in jerry delta-the alt does not have as much resistance[blades turn easyer]
and it puts out more power than wired in star--so it puts out good power with a smaller blade..it gets the power from the extra rpms..because theres less resistance=more rpm.
so no need for a big slow torky blade......least wise thats what i found out messin with my little alt........
WILD IN ALASKA
Re: restless nite (3.00 / 0) (#11)
by hiker (hiker.wild[at]yahoo[dot]com) on Sat Apr 22nd, 2006 at 04:44:30 PM MST
just a addition ..
when i had the alt wired in star it would barely light up my 400watt.38 volt landing light--and the blades would want to stall--need for bigger blades..
when wired in jerry delta it would light up the 38v 400watt landing light[not to full bright but a whole lot brighter than star] and no blade stall[sure could hear the alt workin thou-bzzz]......im just tryin  get the most from a compact unit..
WILD IN ALASKA
Re: restless nite (3.00 / 0) (#13)
by hiker (hiker.wild[at]yahoo[dot]com) on Sun Apr 23rd, 2006 at 02:03:55 AM MST
one more......
the total weight of the alt. is less than 30 pounds..
alt plus tail weigh in at 24 pounds--prop weighs in at about 5 pounds..
WILD IN ALASKA
restless nite | 13 comments (13 topical, 0 editorial)
