My first Windmill set up. | 21 comments (21 topical, editorial)
Re: My first Windmill set up. (3.00 / 0) (#20)
by eformx on Fri May 12th, 2006 at 09:27:59 AM MST
Looks great.  Can you tell us how much cement used to anchor the base? How deep?  Did you reinforce it with rebar?
Thanks,
eformx
Re: My first Windmill set up. (3.00 / 0) (#21)
by cjdock (cjdock@gmail.com) on Sat May 13th, 2006 at 07:53:14 AM MST
The base is 2 feet by 2 feet by 4 feet deep of cement. The angle iron frame is about 3.5 feet long. I used scrape metal to weld the angle iron together. That part isn't pretty but should be pretty strong. I didn't take a pic of it before I buried it. The scrape metal used was c channel, about 4'' wide. A rebar frame attached to the angle iron would have been nicer looking, I just didn't have any.
My first Windmill set up. | 21 comments (21 topical, 0 editorial)
