Diagonal mast turbines & stuff | 25 comments (25 topical, editorial)
Re: Diagonal mast turbines & stuff (3.00 / 0) (#4)
by dalibor (mdalibor - at - gmail - com) on Sat May 13th, 2006 at 12:50:45 AM MST
to see those pics completely i will have to byu plasma displey with 2m diag.
why they are so big? it is hard to get idea properly.
Re: Diagonal mast turbines & stuff (3.00 / 0) (#5)
by pickerol on Sat May 13th, 2006 at 02:53:36 AM MST
Beautiful,
Looks a little like the big vertical sail (40') I saw on the easr coast. Lost the link but that guy used a cloth sail to power a friction heating unit along with power generation. A big cloth pin wheel.
Re: Diagonal mast turbines & stuff (3.00 / 0) (#8)
by MaxT (reconstructionimminent@yahoo.com) on Sat May 13th, 2006 at 04:41:48 AM MST
(User Info) http://koti.mbnet.fi/maxt/
Can you please please remember that link, or some clues to where to find it ?
Re: Diagonal mast turbines & stuff (3.00 / 0) (#13)
by pickerol on Sat May 13th, 2006 at 08:27:58 AM MST
I tried looking again w/o success. The windmill was built by the same people that run/ran Cansolar in Nova Scotia. They had a truck rear end atop a stirdy tower. The drive shaft came down to the ground and had a block of maple spinnig on a glass skinned water jacket. They claimed that this worked as a speed check because higher rpm's caused increased pressure between wood and glass. As well they had several pto's coming off the shaft that spun a geared up induction motor and an air compressor. It was quite a sight...sadly I lost pics after smithfraud virus got into my system last year.
Re: Diagonal mast turbines & stuff (3.00 / 0) (#7)
by MaxT (reconstructionimminent@yahoo.com) on Sat May 13th, 2006 at 04:15:46 AM MST
I made them big so that they can be printed (it's supposed to be printable A4 with 300dpi accuracy... I wonder if that was lost in the .tif to .jpg transformation... ), enlarged, and the blade layer curves can be formed directly on actual life sized blueprint (well, "blueprint-oid" anyways).
For viewing this sort of stuff, I use AC/DC, shareware software with good n' easy zoom in/out tool. (It usually can show any obsucure format and save them in more common formats.
Well... damn.
Should I post much smaller version then ? (enlargement won't be as feasible then, but idea should be clear).
Pseudomax
Diagonal mast turbines & stuff | 25 comments (25 topical, 0 editorial)
