DIY Water Wheel | 13 comments (13 topical, editorial)
Re: DIY Water Wheel (3.00 / 0) (#8)
by dennisbuller (WildWaterPower@msn.com) on Wed Jan 31st, 2007 at 02:24:41 PM MST
(User Info) http://www.WildWaterPower.com
Greetings Pete,
   What is the gear ratio for the wheel to generator?
   What is the normal rotation per minute of the wheel?
Thanks!
Dennis
Re: DIY Water Wheel (3.00 / 0) (#9)
by Pogster on Tue Feb 6th, 2007 at 01:19:51 PM MST
The gearing is in two parts a 1:2 set of cogs and a 1:10 set of sprockets and chain giving me 1:20. The wheel spins at about 60rpm under no load. I've not measured it with the gears and motor connected but would estimate about 40-50rpm.
Pete.
DIY Water Wheel | 13 comments (13 topical, 0 editorial)
