Bigger-box VAWT on real PM gen failed so far... | 21 comments (21 topical, 0 editorial)
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#14)
by disaray1 on Sat Oct 20th, 2007 at 06:12:15 AM MST
 Thats alot of coffee Norm. Here's my modified wing coffee sav...
 I keep changing it's profile to see what happens. Fun!
 David
from cereal boxes to coffee cans ! (3.00 / 0) (#15)
by Norm (peppysue@suite224.net) on Sat Oct 20th, 2007 at 07:22:49 AM MST
Interesting....do you realize that connected
to an alternator like Pico Turbine (except with
magnets like Ed uses instead of ceramics) you
could be lighting maybe a White led?
   How would 4 or 5 stacked on top of each other
work?
 You've right that is a lot of coffee about 1
can a month...they keep piling up they come in handy...
   Is that 2 or 3 blades on yours? You just bend
the flaps away from the rest of the cans right?
   Guess I'll try that with a plastic Folgers
can!
   Thanks for the idea and inspiration.
             ( :>) Norm
( :>) Norm
Re: from cereal boxes to coffee cans ! (3.00 / 0) (#16)
by disaray1 on Sun Oct 21st, 2007 at 12:56:54 PM MST
 I get a can about every three months...Doc said 2 cups a day max.
 Two blades on this one and a three winger on the bench. The latest profile, "M" shaped..
 kinda looks odd but works very well. The next two blade can will have the blades supported in the middle, instead of the trailing edge. Looking for lift.
 Still having good, cheap, wholesome and caffeinated fun. :)
 David
Re: from cereal boxes to coffee cans ! (3.00 / 0) (#17)
by Norm (peppysue@suite224.net) on Sun Oct 21st, 2007 at 06:17:30 PM MST
Yes supported in the middle would be sturdier
and slightly smaller diameter it might go faster
Have you tried the threaded rod and nut method
to see how fast it spins?
Once you get a good design and stack enough of
them on top of each other you would get enough
torque and speed to drive a small stepper motor
....really !
            Have Fun !
             ( :>) Norm.
( :>) Norm
