Bigger-box VAWT on real PM gen failed so far... | 21 comments (21 topical, editorial)
Re: uh (3.00 / 0) (#6)
by DamonHD (d@hd.org) on Thu Oct 18th, 2007 at 01:44:29 AM MST
Remember that I made the toy S-VAWT which does spin.  The problem with the current 'big box' is not enough surface, too thick a shape, and a bit too much cogging, IMHO...
This is what prototypes are for of course.  B^>
If you have a link to plans/pics of the 'quick' design that you have in mind, it may inspire me.
And since I've now got everything set up, all I have to make to test new things is the rotor...
Thanks again for the thoughts!
Re: uh (3.00 / 0) (#7)
by feral air on Thu Oct 18th, 2007 at 01:16:17 PM MST
Not plans exactly but here's a post about it with pics...in my diary if it has 'quick' in the title, that's it. I can go into more detail if you'd like and get a pic of all the pieces before they go together...etc.
You've seen that post before but if you open up the second image in a new window you can see the bracket assembly more clearly...that might help.
Bigger-box VAWT on real PM gen failed so far... | 21 comments (21 topical, 0 editorial)
