Bigger-box VAWT on real PM gen failed so far... | 21 comments (21 topical, editorial)
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#8)
by Norm (peppysue@suite224.net) on Fri Oct 19th, 2007 at 04:07:08 AM MST
Damon,
    Try something like this...but with 2 trash
cans instead of these buckets.( the rims are
bolted together).
   This bucket savonius is about 20 inches high
and 16 inches in diameter, it spins about 200rpm
or better in a 10mph wind (no load) and probably
has at least 5 times the torque of your box...
but I doubt if it could overcome the cogging of
your generator....but bigger like a trash can
will
    ( :>)Norm
( :>) Norm
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#9)
by DamonHD (d@hd.org) on Fri Oct 19th, 2007 at 04:11:36 AM MST
That looks do-able if I don't run out of garden...  B^>
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#10)
by disaray1 on Fri Oct 19th, 2007 at 06:58:34 AM MST
 Norm...you give great advice, I appreciate your posts. Thanks!
  Damon...ck this out
http://www.google.com/patents?id=7J0rAAAAEBAJ&printsec=abstract&zoom=4#PPA9,M1
 Looks alot like your box Sav with a few mods...who knows how well it does, but I found it interesting. A bunch of others here
http://www.google.com/patents?id=aN54AAAAEBAJ&dq=savonius
 Links compliments of Ed Lenz, Thanks Ed!
 David
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#11)
by DamonHD (d@hd.org) on Fri Oct 19th, 2007 at 09:11:36 AM MST
Thanks for those!
Well, I shall try peeling back the main flats to approximate the deisgn in the first link, and may use the cut-outs or a bottle to make the inner rotor!
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#18)
by DamonHD (d@hd.org) on Wed Oct 24th, 2007 at 06:30:55 AM MST
I've tried pulling flaps inwards, and we have a little wind here today, but still no rotation of the big box even though everything else in sight has spun!
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#19)
by DamonHD (d@hd.org) on Wed Oct 24th, 2007 at 07:48:10 AM MST
Sample pic here:
http://gallery.hd.org/_c/mechanoids/_more2007/_more10/turbine-wind-small-VAWT-Benesh-squared-off-pro totype-made-from-large-cardboard-box-on-real-Permanent-Magnet-PM-generator-11-DHD.jpg.html
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#20)
by Norm (peppysue@suite224.net) on Wed Oct 24th, 2007 at 08:48:57 AM MST
I've built your box type and I've built lots of
Savonius type out of buckets, plastic cups,and such....
I've come to the conclusion that they
work better and are easier to make than boxes....
no need to be good at making curves
 when they are already there.
  as in #8
          ( :>) Norm
( :>) Norm
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#21)
by DamonHD (d@hd.org) on Wed Oct 24th, 2007 at 10:38:37 AM MST
Yes, well, I'm definitely up for trying out the dustbin version ASAP: thanks for the pic!
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#12)
by feral air on Fri Oct 19th, 2007 at 02:40:40 PM MST
Norm, I built a Sav. just like that not all that long ago but a bit smaller. I used a pair of those really thin black plastic containers plants come in...it was really flimsy (thicker planters would fix that) and came apart in a big storm but they sure do spin up quick since they don't weigh anything. It was pretty cool watching it destroy itself..that was half the fun.
..it should only take about 10 minutes to make the rotor...good idea.
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#13)
by Norm (peppysue@suite224.net) on Fri Oct 19th, 2007 at 08:58:05 PM MST
Ah yes! Then these,
Look pretty spinning...I imagine 3 or 4 stack
would run an alternator like Ed Lenz's education kit.
 Then of course there is the coffee can one...it
looked like it would work, was easy to build
just coffee cans screwed to a square wood polebut it was a dismal
failure....no overlap.
         ( :>) Norm
( :>) Norm
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#14)
by disaray1 on Sat Oct 20th, 2007 at 06:12:15 AM MST
 Thats alot of coffee Norm. Here's my modified wing coffee sav...
 I keep changing it's profile to see what happens. Fun!
 David
from cereal boxes to coffee cans ! (3.00 / 0) (#15)
by Norm (peppysue@suite224.net) on Sat Oct 20th, 2007 at 07:22:49 AM MST
Interesting....do you realize that connected
to an alternator like Pico Turbine (except with
magnets like Ed uses instead of ceramics) you
could be lighting maybe a White led?
   How would 4 or 5 stacked on top of each other
work?
 You've right that is a lot of coffee about 1
can a month...they keep piling up they come in handy...
   Is that 2 or 3 blades on yours? You just bend
the flaps away from the rest of the cans right?
   Guess I'll try that with a plastic Folgers
can!
   Thanks for the idea and inspiration.
             ( :>) Norm
( :>) Norm
Re: from cereal boxes to coffee cans ! (3.00 / 0) (#16)
by disaray1 on Sun Oct 21st, 2007 at 12:56:54 PM MST
 I get a can about every three months...Doc said 2 cups a day max.
 Two blades on this one and a three winger on the bench. The latest profile, "M" shaped..
 kinda looks odd but works very well. The next two blade can will have the blades supported in the middle, instead of the trailing edge. Looking for lift.
 Still having good, cheap, wholesome and caffeinated fun. :)
 David
Re: from cereal boxes to coffee cans ! (3.00 / 0) (#17)
by Norm (peppysue@suite224.net) on Sun Oct 21st, 2007 at 06:17:30 PM MST
Yes supported in the middle would be sturdier
and slightly smaller diameter it might go faster
Have you tried the threaded rod and nut method
to see how fast it spins?
Once you get a good design and stack enough of
them on top of each other you would get enough
torque and speed to drive a small stepper motor
....really !
            Have Fun !
             ( :>) Norm.
( :>) Norm
Bigger-box VAWT on real PM gen failed so far... | 21 comments (21 topical, 0 editorial)
