Bigger-box VAWT on real PM gen failed so far... | 21 comments (21 topical, editorial)
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#9)
by DamonHD (d@hd.org) on Fri Oct 19th, 2007 at 04:11:36 AM MST
That looks do-able if I don't run out of garden...  B^>
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#10)
by disaray1 on Fri Oct 19th, 2007 at 06:58:34 AM MST
 Norm...you give great advice, I appreciate your posts. Thanks!
  Damon...ck this out
http://www.google.com/patents?id=7J0rAAAAEBAJ&printsec=abstract&zoom=4#PPA9,M1
 Looks alot like your box Sav with a few mods...who knows how well it does, but I found it interesting. A bunch of others here
http://www.google.com/patents?id=aN54AAAAEBAJ&dq=savonius
 Links compliments of Ed Lenz, Thanks Ed!
 David
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#11)
by DamonHD (d@hd.org) on Fri Oct 19th, 2007 at 09:11:36 AM MST
Thanks for those!
Well, I shall try peeling back the main flats to approximate the deisgn in the first link, and may use the cut-outs or a bottle to make the inner rotor!
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#18)
by DamonHD (d@hd.org) on Wed Oct 24th, 2007 at 06:30:55 AM MST
I've tried pulling flaps inwards, and we have a little wind here today, but still no rotation of the big box even though everything else in sight has spun!
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#19)
by DamonHD (d@hd.org) on Wed Oct 24th, 2007 at 07:48:10 AM MST
Sample pic here:
http://gallery.hd.org/_c/mechanoids/_more2007/_more10/turbine-wind-small-VAWT-Benesh-squared-off-pro totype-made-from-large-cardboard-box-on-real-Permanent-Magnet-PM-generator-11-DHD.jpg.html
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#20)
by Norm (peppysue@suite224.net) on Wed Oct 24th, 2007 at 08:48:57 AM MST
I've built your box type and I've built lots of
Savonius type out of buckets, plastic cups,and such....
I've come to the conclusion that they
work better and are easier to make than boxes....
no need to be good at making curves
 when they are already there.
  as in #8
          ( :>) Norm
( :>) Norm
Re: Bigger-box VAWT failed so far... (3.00 / 0) (#21)
by DamonHD (d@hd.org) on Wed Oct 24th, 2007 at 10:38:37 AM MST
Yes, well, I'm definitely up for trying out the dustbin version ASAP: thanks for the pic!
Bigger-box VAWT on real PM gen failed so far... | 21 comments (21 topical, 0 editorial)
