What does this mean? | 21 comments (21 topical, editorial)
Re: What does this mean? (3.00 / 0) (#10)
by Ungrounded Lightning Rod on Fri Oct 26th, 2007 at 10:20:10 PM MST
Cute.
You should be aware that mower engines, being one cylinder and high RPM, have a somewhat limited life - especially in relatively long cycle duty.  They get a lot of power from a small piston by moving it around very fast, so they put more wear on bearings than a slower engine with bigger pistons and more of them.
Automotive alternators, too, have issues with bearings failing after a while:  100,000 miles on a car at 50 MPH is 2000 hours run time - about 83 days continuous, and that's about where they go out.  (Of course they'd probably be running at higher RPM than they would on your mower conversion so they might last longer, since they're at the mercy of the car engine's RPM and have to generate at idle but spend a lot of time at acceleration and cruising engine speeds.)  That's a good match to the mower motor but would be horrible for a wind turbine.  B-)
Anyhoo:  If you end up running this for a couple hours a day figure on it lasting maybe a year or so.  That will give you time to arrange other power sources if this is your only power supply.  (You might want to get another junk mower and a spare alternator for a backup meanwhile.)  If this is just to have 12V available intermittently, you're done.
Re: What does this mean? (3.00 / 0) (#14)
by 3rd Charm on Sat Oct 27th, 2007 at 03:52:51 PM MST
I don't know about that. I've had the same old Sears lawn mower for 20 years now with a 3 hp Tecumseh motor. It isn't used lightly either with a 5 acre yard site full of tree's  to cut around, and many times the whole yard when the rider is on the fritz.
Depends on how a person maintains them I guess. Most people never bother to change the oil in a lawnmower, they just keep adding oil, not thinking that they don't have oil filters and should change the oil frequently.
My riding mower is the same age. The motor runs fine, it's just everything else that falls apart on it, belts bushings and sealed bearing failures.
Re: What does this mean? (3.00 / 0) (#15)
by MaryAlana on Sat Oct 27th, 2007 at 09:45:01 PM MST
My old Sears rider is at 25 years on a brigs 18hp V-twin. Uses some oil now but keeps on running :-)the bearings in a car alternator aren't much different than what you find in some motors so life span would be quite a bit longer if they are kept out of the conditions found under a car hood. extreme cold/heat, wet, dirty, dusty, road salt in northern states.....
What does this mean? | 21 comments (21 topical, 0 editorial)
