Would this make a good dump load? | 7 comments (7 topical, editorial)
Re: Would this make a good dump load? (3.00 / 0) (#7)
by etownlax on Fri Nov 23rd, 2007 at 10:37:12 AM MST
Cause it would be cheaper to just buy a couple more batteries. The only time a dump load is used is when the batteries are full. If you have big enough of a bank then the bank is full less often, with more capacity, in which case the dump load is hardly used much. And More batteries would be cheaper.
-Randy
Would this make a good dump load? | 7 comments (7 topical, 0 editorial)
